Rearend noise when turning slow turns
Old Sep 17, 2010 | 07:11 AM
mainejohn's Avatar
Default Rearend noise when turning slow turns
I have a spooled rearend in my 80 camaro, when i make medium size turns i can hear wierd noises in the rear area of the car, it almost sounds like my leaf springs or sway bar moving alot. could this be from the spooled rearend?
Old Sep 17, 2010 | 09:04 AM
Y2K's Avatar
Y2K
Well yeah it could,you're dragging one tire around corners all the time with a spool,they're really not very good in a street car that has to turn corners.
Old Sep 17, 2010 | 10:03 AM
If you listen close, its your axels screaming for mercy. Spools will bust something fast on the street.
Old Sep 17, 2010 | 10:08 AM
mainejohn's Avatar
is having a spool rearend really bad to have as a 2-3 times per month cruiser?
Old Sep 17, 2010 | 11:45 AM
Y2K's Avatar
Y2K
Better to have a locker or some type of limited slip differential,I'd take corners real wide slow and easy.
You are at risk for axle or gear damage,spools are made for straight line drag racing.
Old Sep 17, 2010 | 01:07 PM
Is it better to hit yourself over the head with a hammer once a day or twice? Twice is worse, but that doesn't make that one time any easier to take. I think you get my drift.
The rearend is making that noise because it's getting stressed out due to having no differential.
Old Sep 17, 2010 | 05:19 PM
The only time I've seen someone get away with running a spool rearend on the street was on a very light roadster (like around 2000 lbs.!) where the tires can break loose every time they turn. If the tires don't break loose turning, then something else has to give or break. Lose the spool and go with something made for corners.
Old Sep 17, 2010 | 05:55 PM
OOORRR just do a burnout every time you turn a corner.
Old Sep 17, 2010 | 11:09 PM
Or, oil up the inner rear tire before taking a turn.
Old Sep 17, 2010 | 11:19 PM
Or... only drive it in the snow!
IROC87
May 15, 2015 04:55 PM
nathanh
Jun 4, 2013 02:12 PM
Xhifer
Oct 9, 2011 12:26 AM
dagger213
LS Series Tech
Feb 23, 2011 02:45 AM
bigredsauto
Apr 23, 2008 11:43 AM
