Squeeking from front end while turning slow or over bumps.
Old Apr 21, 2008 | 01:48 AM
bigredsauto's Avatar
Default Squeeking from front end while turning slow or over bumps.
I picked up an 01 z28 and noticed a few days after I got it that there was an odd squeeking/rubbing noise coming from the front end. SOMETIMES when you turn slowly you can hear it and when you go over bumps you can hear it squeek/rub. Any ideas of what exactly would be causing this? Engine is fine, alignment is slightly off.
Old Apr 21, 2008 | 12:23 PM
baseballer91's Avatar
Default RE: Squeeking from front end while turning slow or over bumps.
see if it happens a lot more than you notice, like while idleing, driving, or when the AC is on etc, it could be the belt.
and its not your brakes?
Old Apr 22, 2008 | 05:03 AM
The belt and entire engine is mint. It idles fine, doenst make noise when AC is on. Its just when turning the steering wheel when im pulling into a driveway/parking lot, and when i got over bumps you hear a squeek. Not bad but it's just something i shouldnt be hearing. its coming from either the steering or suspension i just can't pinpoint it. Brakes sound fine at any speed.
Old Apr 22, 2008 | 01:31 PM
whammer3024's Avatar
ROTM Winner
has any suspension work been done to the car? my guess is something hasn't been greased properly
Old Apr 22, 2008 | 05:07 PM
Yeah most likely. Im gonna take it to a shop for an allignment and i'll have them check it out. Thank you.
Old Apr 22, 2008 | 06:00 PM
Check your sway bar end-links. See if the bushings are worn out or not. If they're shot replace them. You can also give it a blast of penetrating oil between the link bushings and the bar, and at the frame mounts too. I like PB Blaster better, WD-40 doesn't last as long. Sometimes rubber on steel can squeak as the bar tweaks.
Old Apr 23, 2008 | 06:34 AM
Its all about that PB Blaster. I'll give that a try this weekend, I thinkt hat might be the exact problem. Thanks guys.
Old Apr 23, 2008 | 11:43 AM
meteoralp45's Avatar
mine squeels turning left sometimes, mines a bad wheel bearing
IROC87
May 15, 2015 04:55 PM
Crazy_Mike
Aug 15, 2014 08:29 PM
Ladipogi
Mar 14, 2011 10:34 AM
mainejohn
Sep 17, 2010 11:19 PM
