Oil weight, brand recommendations for 70 396
Old Oct 4, 2015 | 03:50 PM
RS SS 396's Avatar
Default Oil weight, brand recommendations for 70 396
New to this forum, sorry if I put 1 questions up, but wanted more info in title. Just getting a 70 Camaro RS SS 396 4 spd and looking for what weight oil, type, brand, etc to use. Also best filter. Thanks for your help!
Old Oct 4, 2015 | 07:23 PM
Bamaro's Avatar
Extra zinc for flat tappets
Attached Thumbnails Oil weight, brand recommendations for 70 396-productlarge2495.jpg
Old Oct 4, 2015 | 07:55 PM
MKCoconuts's Avatar
There's two ways you go about it. You can buy oil off the shelf from your local auto parts store and add a zinc additive. Or order oil off Summit or Jegs that is specifically for older cars. Anything you find local will be the newer API desigination which has ~900ppm zinc and 770ppm phosphorus, compared to your older SJ which was ~1280 Zinc and ~1300 Phosphorus. 10W-30 or -40 would be the way I'd go. You'd be find with 5W-30 or -40 as well.
Old Oct 6, 2015 | 12:00 PM
Or you could simply go to your local parts store and buy either Valvoline VR1, which has more zinc. Brad Penn is also available in most larger market places, but a bit more money. VR1 is the best bargain price, and more zinc than even Brad Penn.
And Wix is the best filter on the market. NAPA Gold is also made by Wix, and equally good. If you want lots of capacity, but the Wix or NAPA Gold #1794.
Old Oct 6, 2015 | 12:19 PM
I've been using Mobil 1, since it's bargain priced at Walmart. I put that stuff in everything. Then add a bottle of STP Oil Treatment, which contains ZDDP. STP doesn't disclose their ppm level though.
Old Oct 11, 2015 | 06:58 AM
RS SS 396's Avatar
Thanks for the help!
blackbeauty1995
Dec 21, 2013 08:46 PM
osduck5
Jul 6, 2009 05:27 PM
cambonesian
82-92 V8 Tech
Oct 26, 2007 07:10 PM
hackson
Jul 17, 2007 09:25 AM
Ejam
Mar 31, 2007 10:26 PM
