how much oil and what weight for a 99 z28?
Old Jul 15, 2007 | 09:17 AM
hackson's Avatar
Default how much oil and what weight for a 99 z28?
DONT HAVE A MANUAL
need to know how much oil and what weight I need to run. I live in missouri and am gonna run synthetic.
thanks
Old Jul 16, 2007 | 09:10 AM
hackson's Avatar
Default RE: how much oil and what weight for a 99 z28?
oh cmon someone has to know the answer to this.......
Old Jul 16, 2007 | 10:22 AM
Danscamaro02SS's Avatar
i run Valvoline 5w30SYN winter 5w40SYN summer
Old Jul 16, 2007 | 10:57 AM
hackson's Avatar
is that what the manual recomends?
Old Jul 16, 2007 | 01:28 PM
ya the manual recomends 5w30 and you didnt say how many miles is on it over 100K i would run 10w30 Valvoline Maxlifesyn i used to work at a lube shop if its a LS1 it will take 5.5q you have to let it sit for 15mins when you check the oil level & a V6 should take 4 - 4.5q
Old Jul 16, 2007 | 02:17 PM
hackson's Avatar
yes it is just over 100k
are you sure I should run 10w30 instead of 5w30? that isnt gonna hurt anything? as i know people who have ran the wrong weight of oil in other cars and had problems...
thanks
Old Jul 16, 2007 | 03:39 PM
well if its not leaking you could run 5w30 but i would at lease run Valvoline Maxlife or run Maxlife synthetic when i worked at Valvoline instant oil change that stuff stop leaks and stop oil burning now i dont know if your car does any of that but its better to use it before it happens im goin to start to use it at 75,000 i have a while before that
Old Jul 16, 2007 | 10:30 PM
95slvrZ28's Avatar
Some cars are very particular about what oil you put in them. I've seen cars that burn oil from one brand, but not the other even if they're the same weight. My Dad's LS1 vette would burn a bunch of Mobile 1 10W-30 synthetic, but wouldn't burn nearly as much if he put in 5W-30. Just some food for thought there.
Old Jul 17, 2007 | 09:25 AM
hackson's Avatar
i talked to someone in my family and they suggested that i stick with 5w30 if that is what is called for and only switch if there are some problems.
I will try using the valvoline maxlife synthetic or whatever.
thanks!
refderek
Dec 5, 2012 04:35 AM
blue87iroc350
Jan 11, 2010 08:49 PM
GoofieJ21
Feb 19, 2009 03:15 PM
cambonesian
82-92 V8 Tech
Oct 26, 2007 07:10 PM
RatedZ
Dec 10, 2005 03:15 AM
