Oil Leak
Old Aug 11, 2011 | 09:56 PM
Originally Posted by mr.blue
speaking of the rear main seal, how hard is it to replace with the transmission and torque converter out of the car?
Easier than if it's in, but not much different. It will require pulling the pan, so with the tranny out you'll need to support the engine from above, so you can pull the pan. Most 2nd gens will require the motor mount bolt to be removed so you can lift the engine enough to remove the pan.
Once the pan is off then it's removing the rear main cap and if it's a 2 piece seal you can work it out with a seal puller, then push the new one in around the crank. You have to be careful not to shave any rubber off the seal when installing, or it will leak again.
On a one piece seal you need to drop the crank to replace it, so I usually pull the engine out to do them; just lots easier for me.
Old Aug 12, 2011 | 10:13 AM
mr.blue's Avatar
damn, sounds like way too much work for a seal. i have been getting screwed by shops lately so i wanted the guys at the transmission place to do it since the seem to be a pretty honest group. i'm sick of having cardboard all over the garage floor you know?
Jelz28
Jul 18, 2012 06:01 PM
95mero
Jan 5, 2009 09:14 AM
derrickdiggler
Oct 12, 2007 01:22 AM
derrickdiggler
Sep 27, 2007 02:26 PM
daltons 1980
Sep 24, 2007 09:04 AM
