oil galley plug... leaking HELP
alright, I've had this 305 for a long time and its been leaking oil for a while at first it wasn't noticeable, but it got worse and started leaking so bad I could not even drive it without a trail of smoke following behind it. How embarrassing right. I finally was able to locate where the leak was coming from. It seems to be coming from an oil galley plug that is located on the top of the block in the rear. There are two oil holes there and one I am currently using for my oil pressure line. And the other is currently leaking. It does not want to hold good oil pressure after warming up, and I have currently tried to fix this leak, but when I took the Intake and drivers head off I got to it and it seems to be siezed up in the hole only rounded out the 1/4 square insert. I need to get ideas on either how I could get this plug out while the engine is still in the car I need it to drive daily and can't keep affording the masses of oil I am currently using. Any ideas would be helpful and if anyone knows how I could get this out without getting metal shavings in the oil I would be greatly appreciated. Thank you. My name is Andrew and am looking for anything to help. Even just sealing the hole if possible I don't use it for anything.
If it's rounded off and no way to get to it to drill it out, then I'd probably make it permanent. If you spray it with brake cleaner, and then brush it with a stiff wire brush until it's very clean, you can probably seal it up with JB Weld. Unless you're willing to pull the engine to address the stuck plug, I doubt you'll get a rounded off plug out to do a proper repair, and JB Weld may be your only option.
Gathering oil from a leaking rear intake valley gasket (more common than the plug) would make it seem like it's coming from the plug you're talking about. Clean that area off real well and check it again to make sure that what it is, is how it "seems".
thanks, and ya I'm pretty sure its coming from that hole just because once I had put shelled over it and it slowed it enough to where it didn't spray only a small leak came out and u could follow it from underneath and follow it all the way to the plug.
