81livelong |
02-16-2014 04:11 PM |
oil galley plug... leaking HELP
alright, I've had this 305 for a long time and its been leaking oil for a while at first it wasn't noticeable, but it got worse and started leaking so bad I could not even drive it without a trail of smoke following behind it. How embarrassing right. I finally was able to locate where the leak was coming from. It seems to be coming from an oil galley plug that is located on the top of the block in the rear. There are two oil holes there and one I am currently using for my oil pressure line. And the other is currently leaking. It does not want to hold good oil pressure after warming up, and I have currently tried to fix this leak, but when I took the Intake and drivers head off I got to it and it seems to be siezed up in the hole only rounded out the 1/4 square insert. I need to get ideas on either how I could get this plug out while the engine is still in the car I need it to drive daily and can't keep affording the masses of oil I am currently using. Any ideas would be helpful and if anyone knows how I could get this out without getting metal shavings in the oil I would be greatly appreciated. Thank you. My name is Andrew and am looking for anything to help. Even just sealing the hole if possible I don't use it for anything.
