new member
Old Jan 5, 2010 | 07:43 PM
  #21
Well they look to be correct, but of course they're upside down. If you turn them over they will be correct, and then you'll need to remove whatever bolts are between the turnsignal and the upper header panel and lower valance panel to slip them in.
They sure don't look like std. brackets (which your car should have had) but they're RS brackets that will fit the bumperettes. Not sure if they'll work with a std. Camaro until you try them. Most people who convert from std. to RS use the std. brackets on the little RS bumperettes.
I can just see what looks like the supports hanging down above the turn signals, so they should also bolt to the brackets. I don't see the filler plates, but they aren't really needed except to hide the bracketry.
Should be 3 bolts into the core support, and then all the bumper bolts, etc. and support bolt.
Old Jan 5, 2010 | 10:31 PM
  #22
Dj Aztek's Avatar
my bad
Old Feb 16, 2010 | 08:01 PM
  #23
Dj Aztek's Avatar
Default update
got a new exhaust system on the car and it sounds bad *** now i just need to clean the chassis or the bottom part of the car as well . also staring to peace together the inside of the car.
Old Feb 16, 2010 | 11:08 PM
  #24
Looks good. Where does it exit? Out the back, or behind the rear wheels?
Old Feb 17, 2010 | 12:14 AM
  #25
Dj Aztek's Avatar
the back ill take some pictures 2morrow
Old Feb 18, 2010 | 10:42 AM
  #26
tbl76camaro's Avatar
Looks good so far. What kind of exhaust is that? Plans on paint?(Colors)
Old Feb 18, 2010 | 11:55 AM
  #27
Dj Aztek's Avatar
the mufflers are wicked flow there sound real good. about the paint i'm still thinking about orange with white stripes or the original green color with black stripes.
Old Feb 18, 2010 | 07:55 PM
  #28
My new exhaust system fell apart today! I planned on tack welding the joints as they were all assembled with muffler clamps, and I don't trust them. Anyway, it didn't really come completely apart as the hangers held it in place, but it started banging againt the swaybar, so I got under there and found it had slipped in the muffler.
So I went and got the MIG welder and put it back together, then welded the joints to hold it. Hate it when I know I should do something right, but wait until it falls apart to do it!
Old Feb 18, 2010 | 11:44 PM
  #29
Dj Aztek's Avatar
lol
jimbo50
Sep 1, 2018 03:33 PM
Red99CamaroRS
Jul 2, 2009 12:15 AM
keithcfh11
Jun 30, 2009 08:30 PM
Import_Muscle
Apr 23, 2009 07:47 PM
WannaCamaroSPP
Feb 5, 2009 01:49 PM
