Intake problems !!!
Old 03-21-2011, 02:13 PM
With the gaskets in place, can you view the mating surface of the intake to the heads straight on to see that the angles are the same? Even check gaps top to bottom with a feeler gauge or fine wire. If something is different with the angle match, you can end up with a manifold vacuum leak.
  #22
Old 03-22-2011, 06:43 PM
kyles_81camaro's Avatar
well i drilled the wholes out and it bolted up just fine... ill have to get the rest of it put together and see if it does leak or not.
carid
Vendor Special Buys
01-20-2015 07:08 AM
zidane_aj
06-01-2010 03:44 PM
schwab7777
06-21-2009 12:09 AM
cubancamaro
02-21-2007 09:41 PM
derek
05-19-2006 01:24 PM
Quick Reply: Intake problems !!!
