getting on the road
Old Feb 17, 2011 | 01:03 AM
  #351
james hellsing's Avatar
Well for timing idk what this RV cam is specd at so all I can do really is time it for stock cam, And I had it lean with the mixture screws on the carb on the old set up so retuning for the new engine should help
Old Feb 17, 2011 | 08:30 AM
  #352
May have to tweak the timing a little if it's not a stock cam and you set it at stock timing. Aftermarket cams often wont be close to the same timing marks, so if it doesn't run OK with stock timing, just move it a few degrees and drive it.
Old Feb 17, 2011 | 09:00 PM
  #353
advance or retard though?
Old Feb 17, 2011 | 10:01 PM
  #354
Without a cam spec I can't say. Just have to try it until it runs good and starts easy.
Old Feb 17, 2011 | 10:27 PM
  #355
It already runs good and starts easy at 6* advance, the only problem is if I nail it then it bogs a little but if it's just cruising it's fine.
94junker
Jun 15, 2010 11:36 PM
maguilar496
May 6, 2010 12:18 PM
palomba15
Nov 12, 2008 12:37 AM
Chappie99
May 11, 2008 09:59 PM
