New Ultra Avenger and fuel line
Old Feb 16, 2011 | 07:24 PM
badazz81z28's Avatar
Default New Ultra Avenger and fuel line
Open to some ideas. Im currently running a -6AN fuel line set-up. The new Ultra avengers has inline bronze filters in the bowls. This prevents me from using my current set-up because my extensions go directly into the bowls. What have you all done? I would hate to remove the bronze filters and an inline is what I wanted to get rid of.
Thanks,
Old Feb 16, 2011 | 11:41 PM
I'm not sure what your talking about. I'll do some home work, BRB.
Old Feb 17, 2011 | 08:32 AM
I always dump those bronze filters, and go with inline filters. They're crap and easily plug up. I actually run two filters on an electric fuel pump system, and one on mechanicals. On electric pumps I put one before the pump and onbe after. On mechnicals I put one after the pump.
Old Feb 17, 2011 | 08:57 AM
If your familair with the basic 4150 carbs, you know how it has those 7/8-20 adapters in the fuel bowl so you can run those cheapie 3/8" metal lines? Well if you pull those adapter out there are bronze filters in there. Older 4150s have the same set-up w/no filters. The fuel line I have now is tapered at the adapter end and not cupped like the stock adapters. Which means the room for the filters is non existent. I would like to run these filters because I would like the clean look of just the hose from the pump. Im open to ideas, there doesnt seen to be such a carb inlet extention to allow me to use them.
Old Feb 17, 2011 | 10:01 AM
Just put the fuel filter down under the frame before it gets to the pump and you'll have a clean look and no bronze filters.
Old Feb 18, 2011 | 03:43 AM
Do you have a fuel log or a "T" with two short pieces coming out? If you have a log, you can get a filter the threads on the end of it. Then it looks like part of the log and will most likely be hidden by the air cleaner any who.
This threaded into this
raymond11926
Dec 20, 2014 02:40 PM
JBurg86
Dec 11, 2012 01:56 AM
manslaughter299
Jul 24, 2012 03:17 AM
Cactus
Jul 18, 2010 08:46 AM
albo1989
82-92 V8 Tech
Jul 9, 2010 11:27 AM
