gearing????
Old Oct 30, 2006 | 03:14 PM
danny67's Avatar
Default gearing????
can anyone recommend a rear end ratio?? at 65mph I am taching 3000 rpm, wnat a better cruising speed
Old Oct 30, 2006 | 03:19 PM
shnormo's Avatar
Default RE: gearing????
You need more info than that. You also need tire size. I'm not sure of the exact Formula
Old Oct 30, 2006 | 04:54 PM
danny67's Avatar
really? the car has gobs of power, just want a higher gearing
Old Oct 30, 2006 | 05:10 PM
uncle bill's Avatar
Sounds like a 3.73 now, I've got 4.10's and they tach 3000 @ 60 mph. I don't know what You want though.
Old Oct 30, 2006 | 06:48 PM
SickSickSick's Avatar
the lower the gear ratio the slower your takeoff. if your wanting highway gears 3:23 or 3:42. Sick
Old Nov 3, 2006 | 12:19 AM
69camaro1's Avatar
This is not a direct formula but here it is. If you enter a mph and different gear ratios over and over you will find the gears your looking for.
(MPH*rear gear ratio*336)/Tire diameter
Old Nov 3, 2006 | 03:35 AM
v8chvyguy's Avatar
4.10 is a low gear ratio, 3.42 is a high gear ratio. Lower gears launch quicker and top out sooner, unless you got a screamer motor that makes power up high. Adding an overdrive unit will give you the best of both worlds. You can keep your low gears and still get highway drivability with good fuel mileage. We are a Gearvendors retailor, they are pretty nice, It turns a 5 spd into an 8 spd. with the ability to split each gear. Or you could just swap out your 3 or 4spd trans for a 5 spd gearbox.
Old Nov 3, 2006 | 02:14 PM
OOPS i did say lower huh? LMAO Sick
Old Nov 4, 2006 | 12:08 PM
v8chvyguy's Avatar
Sorry sick, I hated to point that out.
maroz2894
Aug 1, 2009 08:48 AM
jrsporsche
Jul 17, 2009 02:34 PM
joker905
Sep 10, 2008 10:45 PM
95camz28
Dec 4, 2007 10:19 AM
pony_tammer
Jul 23, 2005 05:51 PM
