Electric choke wiring
Old Nov 18, 2019 | 11:22 AM
mdmcbride1's Avatar
Default Electric choke wiring
Hey guys. Recently got my hands on a 4 barrel Edelbrock Carb with an electric choke. Got it installed but I'm a bit unclear on how to wire the choke. I know it needs 12V when ignition is on. On the fuse box on the driver's side I see three terminals labeled BAT, ACC, and IGN. IGN has a wire hooked up, and I know I shouldn't use battery or the choke would be getting power all the time, but would the ACC terminal work? Any help is appreciated.
Old Nov 20, 2019 | 07:08 PM
Everett#2390's Avatar
You can use ACC terminal for choke. Better yet, use ACC for energizing a Bosch relay and wire choke power from it using battery power to the other side/contact.
DrPepper1010
Aug 29, 2017 02:52 PM
dragonmas
82-92 V8 Tech
Oct 11, 2015 11:57 PM
BLK79
Jun 3, 2014 08:40 AM
77Lttype
Nov 5, 2011 12:49 AM
80ZJoe
70-81 V8 Tech
Jun 13, 2011 09:56 PM
