Electric Choke Power
Old Aug 28, 2017 | 06:42 PM
DrPepper1010's Avatar
Default Electric Choke Power
I have an 81 Z28 w/ a 350. I've removed the ECM and just installed a Holley 4175 spread bore carb w/ electric choke.
The wire that goes to the electric choke is light green and has NO voltage when the car is running. It should be a switched 12v.
Does anyone know where this wire goes? I don't see anything on the fuse block that relates to the choke.
Could this have originally gone to the ECM? If it does go to an ECM connector, under the dash, I can trace it and tie it into a switched 12v source.
Any insight will be appreciated.
Old Aug 28, 2017 | 07:16 PM
Everett#2390's Avatar
It may have came from ECM.
But, you can get power from ACC spade on fuse panel.
Old Aug 29, 2017 | 02:52 PM
Issue solved. Found an on-line wiring diagram and located a switched 12v source in the engine compartment.
anthony7888
70-81 V8 Tech
Jun 19, 2011 03:07 AM
80ZJoe
70-81 V8 Tech
Jun 13, 2011 09:56 PM
Cblaze
82-92 V8 Tech
Jan 31, 2011 07:09 PM
mikeatwo
Oct 3, 2006 08:27 PM
