4 speed Muncie transmission
Old Oct 15, 2020 | 09:44 PM
dmancha's Avatar
Default 4 speed Muncie transmission
Having trouble with the reverse lockout linkage. Linlage is up against the header pipes and can't get into reverse or neutral. What will happen if I remove the back drive rod? This is the rod that is up against the header pipe. Will this effect the shifting, or anything else?
Old Oct 16, 2020 | 07:53 AM
Zspoiler's Avatar
You could modify the linkage rod and or just remove it and use a Hurst backup light switch .Of which I have done .
Old Oct 17, 2020 | 10:36 AM
Can't you just bend the pipe away; Any exhaust shop can fix this in a few minutes.
Old Oct 17, 2020 | 05:43 PM
dmancha's Avatar
Thanks for very helpful suggestions. I am going to act on these,
1967Hawaii
Nov 6, 2019 01:35 PM
mainejohn
70-81 Transmission & Differential
Mar 3, 2011 12:22 PM
mainejohn
Dec 1, 2010 11:12 PM
nazariol
Sep 14, 2009 06:05 PM
v8chvyguy
May 19, 2007 10:51 PM
