what make of 80 camaro 4 speed?
Old Dec 1, 2010 | 09:37 AM
mainejohn's Avatar
Default what make of 80 camaro 4 speed?
I have a new 1980 camaro in a 4 speed. that tranny is it? muncie or saginaw? to put it in reverse you pull it up and down next to 2nd gear. it seems every one i have seen they are down next to 4th gear!
Old Dec 1, 2010 | 11:56 AM
It should be up next to first. Its either a Saginaw or Borg Warner ST 10. If its an aluminum case is a Borg. Probably a Borg anyhow.
Old Dec 1, 2010 | 12:03 PM
mainejohn's Avatar
no reverse is down next to 2nd gear. i have to pull the shifter **** up and down to put it in reverse and have to do that to get the key uot of igntion.
Old Dec 1, 2010 | 01:25 PM
If its a borg warner it will have an aluminum case and a iron side cover w/ I believe 9 bolts and the reverse linkage will be in the tail shaft. A Saginaw will have an iron case
Old Dec 1, 2010 | 02:01 PM
mainejohn's Avatar
http://i537.photobucket.com/albums/f.../tranny243.jpg
here is a picture of the numbers! does these help to ID?
Old Dec 1, 2010 | 03:37 PM
#3925656 is a 1968-69 vintage Saginaw. The 9218 would be the cast date: September 21, 1968. http://www.camaros.org/trans.shtml#4speed
Old Dec 1, 2010 | 03:53 PM
mainejohn's Avatar
so is that good or bad? stong or weaK? thanks for the help!!
Old Dec 1, 2010 | 04:10 PM
It can easily handle 350 lbs of torque, which is more than what a small block of your cars vintage puts out. I have even read of guys drag racing with the Saginaw too, so they're not junk just because they're not a Muncie.
Old Dec 1, 2010 | 04:14 PM
mainejohn's Avatar
the guy i bought the car from said the whole tranny was rebuilt. So is that the only 4 speed that has the reverse down next to 2nd gear?
Old Dec 1, 2010 | 04:19 PM
As far as I'm aware. The only other trans that I know with that pattern is the old 60's style Fords.
