Car won't go into gear
Old Feb 19, 2013 | 05:38 PM
63StingRay's Avatar
The Saga Continues----on my '69 with the steel bellhousing, I removed the front block plate, installed new clutch disc , and adjusted the fork ball as far forward as possible and now the clutch fork is hitting the floor pan. Its almost like the bellhousing rose higher to hit the floorpan. It doesn't make any sense. Could the rear transmission rubber bracket be to tall? (it looks aftermarket). Any ideas???
Old Feb 19, 2013 | 05:47 PM
63StingRay's Avatar
also is there a way to check if the engine/transmission is sitting in it's proper angle?
Old Feb 19, 2013 | 07:25 PM
Everett#2390's Avatar
If I remember, the trans isolator height is about 1.25 inches, maybe 1.5.
The trans crossmember has three holes in the flanges for an OE shifter.
These holes should be on the drvr side.
A quick check of angles is measure the driveline angles of both sides of the yokes at both ends.
There should less then 1° difference between the two ends.
The distance of the pivot ball from the engine side of b/housing should be 4.75 inches.
The correct fork ends in 638, I think.
Old Feb 19, 2013 | 08:05 PM
Make sure you're using the correct clutch fork. There are bunches of different style GM forks that have different bends to them.
Using the wrong one can give you clearance issues, as well as affect the throw of the clutch: Pictures and Identification of GM Clutch release forks.
Old Feb 21, 2013 | 03:50 PM
63StingRay's Avatar
This is what I have come up with so far. The flywheel is an aftermarket 11" aluminum HARVEY, a worn out 11" clutch disc, stock 11"pressure plate and a fork out of a '76 Camaro with short throwout bearing and Lakewood bellhousing. Quite a circus. A friend is digging through his stash for a stock flywheel, bought a new stock 11" clutch disc, use the same pressure plate, ordered new fork (thanks for the ID chart of forks Mr.69) and new throwout bearing. Hopefully the Lakewood bellhousing will cover everthing up. Oh yeah, removed the enging block plate. NOW, maybe I can get some clearance on the fork-floorboard problem. And Everett, thanks for the geometry lesson. Some of it I actually figured out. Soon as I get this all put togather, "I'll be baaack!"
JordanN
Jun 2, 2012 09:40 PM
3.4putter
Jan 28, 2012 07:35 PM
numskull223
Jan 17, 2012 04:29 PM
SS_2000
LS Series Tech
May 24, 2010 07:50 AM
VTownSuzieQ
Nov 24, 2006 09:28 PM
