Front Coil spring insulators on top or bottom?
Old Dec 10, 2012 | 08:47 PM
motobro's Avatar
Default Front Coil spring insulators on top or bottom?
Hi,
I recently replaced the ball joints,shocks (koni), bushings, sway bar, painted the upper and lower control arms.
When I reinstalled the coil springs I did not put any insulators in because i didnt take any out.
It makes a little noise now that I dont like and i feel some of the vibrations from bumps in the road.
Did the car come with coils spring insulators ?
How much difference do they make ?
Were they on the top or bottom or both ?
Any input would be greatly appreciated !!
Thanks
Old Dec 11, 2012 | 08:41 AM
77thor's Avatar
First gen Camaro's never came with coil spring isolators.
Old Dec 11, 2012 | 10:49 AM
On cars that used them the isolator pads were on the bottom, but as mentioned 1st and 2nd gen Camaros didn't use them. My new coils and rebuilt A arms made a few strange noises when first installed. Eventually they stopped after some miles on them.
Old Dec 11, 2012 | 11:51 AM
Or you can add a set of spring isolators, they go on the top of the springs (between the spring and frame naturally): 1967-1981 Camaro Front Coil Spring Isolator
It's interesting though, that you can buy "correct" replacements for something GM didn't put on in the first place?
Old Dec 11, 2012 | 02:13 PM
77thor's Avatar
I would hold off on doing anything for a while... give the springs some time & miles to finally get seated.
Raindem
Jul 13, 2012 03:28 PM
T&GCAMARO
Apr 14, 2010 07:43 PM
sempersuntzu
Aug 4, 2009 12:25 PM
blkgagt94
Feb 17, 2008 10:02 AM
toolbox
Mar 16, 2006 10:52 PM
