Front coil spring removal
Old Jul 10, 2012 | 12:34 PM
Raindem's Avatar
Default Front coil spring removal
How do you get the front springs out if the sub-frame is already removed? The procedure in my Chilton's book requires the weight of the vehicle to be bearing down.
Thanks
Curt
Old Jul 10, 2012 | 01:31 PM
Raindem's Avatar
Well, I found this procedure How to install front coil springs without killing yourself! but it will require I get different spring compressors (mine only have 1 hook at each end).
Any other tricks?
Old Jul 13, 2012 | 09:36 AM
I don't know of a way to put them in, or get them out without the twin hook compressor if you don't have the engione weight on it.
Old Jul 13, 2012 | 03:28 PM
Raindem's Avatar
I bought a brand new $80 compressor and tried the method describe in the link I posted. It didn't work... the compressor actually stripped it's threads trying to compress the coil. Good thing that I had the safety chain on.
Then I tried another method of using a 10k lbs tie-down to wrap around your floor jack and the frame, and jacking up under the LCA. It felt awkward but it worked. I got both springs out and I'm still alive.
motobro
Dec 11, 2012 02:13 PM
T&GCAMARO
Apr 14, 2010 07:43 PM
blkgagt94
Feb 17, 2008 10:02 AM
buckmaster
Nov 24, 2007 11:46 PM
toolbox
Mar 16, 2006 10:52 PM
