67 RS hideaway headlights
Old Feb 22, 2010 | 06:56 PM
jt69's Avatar
Default 67 RS hideaway headlights
Been helping a friend with his lights. Can't figure out what the diode wire does. Lights will come on and doors open when you pull the headlight switch on. Push it off, lights go out and doors stay open. Have print shows diode wire going to the accessory post on ignition switch. Any info will be appreciated. This car was disassembled. It is the original wiring harness. All new relays, motors/ Been working on this for 2 weeks now. Thanks, jt69.
Old Feb 23, 2010 | 03:30 PM
mcmcmahon's Avatar
try here. http://www.gvtc.com/~rlaa/ look in 1967-69 rs console gauge & headlight wiring diagrams. the diode only lets voltage travel one way, make sure you have the arrow in the right direction.
Old Feb 24, 2010 | 07:00 AM
jt69's Avatar
Thanks for the info.I am new to this web site just learning how to talk to folks.I have a 67 camaro that i restored and a 69 that i am just starting on.
Old Feb 25, 2010 | 12:41 PM
mcmcmahon's Avatar
good luck with your projects.
Old Jul 20, 2010 | 10:11 AM
CamaroBeau's Avatar
Smile
Do you really have to fixed the wiring for the headlights? Is it necessary to have the original wiring in the restoration?
Old Aug 23, 2010 | 12:19 AM
brownr72's Avatar
Please check the anode and cathode connections...they might be interchanged.
Old Nov 11, 2010 | 06:45 PM
john h's Avatar
My left head light door opens and then will not close unless I lift the door off the limit switch on the core support. I changed the limit switch and same thing. I have voltage at top and bottom of switch. checked ground on switch and good. I took the switch loose and left it hooked up and now the door operates normal. Whats going on? Any help would be great.
Old May 24, 2020 | 11:58 AM
Big Ern's Avatar
When I was struggling with mine, I didn't realize that they have to ground back through the headlight bulbs, be sure that you don't have a burned out bulb
MOmilkman
Jul 28, 2015 11:18 PM
dtkarst
Jun 1, 2013 08:51 PM
carsearching
Nov 23, 2011 06:15 PM
bohuntr
Sep 26, 2009 07:33 AM
67RS Vert
Dec 30, 2005 11:43 AM
