A/T cable adjustment
Old Nov 4, 2018 | 08:25 PM
SuperSport_Shawn's Avatar
Default A/T cable adjustment
so is it possible to adjust the shifter cable on an A/T if it’s stretched ? Here is the scenario, went for a cruise and when I came home and put it in park , it rolled back and made some clinking noises as if it were between gears (P-R) and when I turn the car off I was not able to turn the key to the off position or pull the key out.. so I jumped on the forum and read that if I was able to turn the bottom of the steering column counter clockwise and put it in park like that then it is a stretched shifter cable..
so I read that they are adjustable with a linkage , is that still possible if it’s stretched or does it need to be replaced ?
Old Nov 6, 2018 | 07:05 PM
Everett#2390's Avatar
This picture from 69 Service Manual may help.
Loosen two bolts and adjust accordingly, then adjust lockout rod to lock ignition.
Old Nov 7, 2018 | 07:38 AM
ok so I’ve been lucky enough to never have to do this so I’m quite lost.. so the adjustment would take place at the shifter itself and not at the transmission? The bolts you speak of are the bolts (A&B) in the diagram ? And that lock out rod is on the fire wall next to the brake booster correct ? Sorry for your troubles
Old Nov 7, 2018 | 06:59 PM
Yes, correct, Bolts A & B. No problem, keep asking to learn.
Old Nov 8, 2018 | 08:20 AM
thanks , I’ll give it a shot this weekend , now I just have to figure out how to take the console out to get to the shifter
Old Nov 8, 2018 | 05:51 PM
Four screws in removing shifter plate.
Pretzel
Oct 6, 2013 02:01 PM
92-RS
Aug 20, 2011 12:59 PM
20_jeff_02
LS Series Tech
Aug 18, 2010 08:25 PM
Furr1970
Dec 23, 2007 01:17 PM
microkid
Jul 29, 2007 04:52 PM
