Lowering the front end
Old Mar 3, 2007 | 10:26 PM
pistolpete_67's Avatar
Default Lowering the front end
I'm going to buy some lowering springsto drop the front end of my 67 acouple inches. My question is, can I just pull out the shocks and use some spring compressors to compress the spring and pull it out, or do I have to separate the ball joints and pull it out that way? Maybe I'm thinking into this too much. Any suggestions?? Thanks...
Old Mar 4, 2007 | 10:31 AM
skar's Avatar
Default RE: Lowering the front end
I also would like to know.
Old Mar 4, 2007 | 11:54 AM
ghotachevy's Avatar
ur better buyin drop spindles they dont change the geometry of ur control arms if ur gonna drop it more than a inch or so
Old Mar 4, 2007 | 01:08 PM
JD1969's Avatar
^^ he's right but you can use a spring compressor after you remove the shocks. What are doing for the rear end? I hope you drop that a bit too.
Old Mar 4, 2007 | 01:46 PM
ghotachevy's Avatar
it prob faster just to knock the ball joint off though so your not fightin **** just drop out and slap back in
Old Mar 4, 2007 | 03:05 PM
68maro's Avatar
Not that easy bud. You better be very careful cause if that spring comes flying out it'll kill you.
Get help from someone who has done this before. Put your car on jack stands high enough so the lower control arm can swing down. Keep your jack under the lower control arm your working on to keep pressure. I believe I popped just the lower. As safety I stuck a pry bar thru the coil from the top to the bottom. Lower the jack slowly.
Old Mar 4, 2007 | 04:46 PM
ghotachevy's Avatar
well i didn't mean just un bolt the damn thing and let i t fly BUD was saqying it would be faster to drop lca then finagle everything in and out while together
Old Mar 4, 2007 | 10:20 PM
I actually bought the car wrecked in the front end, so I had to put a new sub frame on it and the shop that did it for me put some stock springs in the front, when the rear was already dropped a little bit, so now it looks stupid. I rented some compressors from Hertz Rental Center before that basically look like big C clamps that I figured I could put on both side of the spring and pull it out, but it sounds like it will probably be safest to drop the lover control arm likeyou guyssaid.
Old Apr 13, 2007 | 07:45 AM
chacey's Avatar
just be very careful in doing it. be sure that the gm ball joints are properly tightened and installed, to avoid problems.
Old Apr 17, 2007 | 03:10 PM
1969 SS's Avatar
I never use a spring compressor(some of them are hard to fit). I just put my jack under the lower control arm and lower slowly.
they won't teach you that in school though
Rose350
Jan 13, 2013 10:28 AM
sreed1236
Jan 7, 2013 08:40 PM
78LT350
Jan 11, 2008 11:32 PM
doinbout150
Oct 8, 2007 09:32 PM
