Lowering springs in the front! What about shocks??
Old Nov 1, 2007 | 11:59 AM
78LT350's Avatar
Default Lowering springs in the front! What about shocks??
Hey guys! I need some help on this one...I have hotchkis lowing springs in the front of my 78, so it lowered my car about 1.5'. The problem is that I'm bottoming out when I hit a dip on the highway. It rubs on the outside of the tread and its ANNOYING! I think I need to replace my shocks because they are old and worn out, but which ones will fit now since I lowered my car? Any suggestions on shocks I can get that will stop me from bottoming out?? Thanks a lot!
Old Nov 2, 2007 | 01:01 PM
1969 SS's Avatar
Default RE: Lowering springs in the front! What about shocks??
what kind of shock do you have and how old are they?
what size tires do you have?
Old Nov 2, 2007 | 10:10 PM
JRs72RS's Avatar
February 2009 ROTM
You can switch to a stiffer shock, that may cure the rubbing and give you better handling. But, if the picture is current, it looks as though the backspacing on your wheels might be the culprit. Increasing the backspace will put the tires back into the wheel well. 1969 SS also has a good point, oversize tires can add to the problem.
Old Nov 3, 2007 | 01:59 PM
78LT350's Avatar
Thanks for responding guys. 1969ss, They're just regular shocks from Kregan auto parts....Monroe Sensa-Trac that I bought about 2-3 years ago. I don’t know if Monroe’s are good shocks but I want to invest in something more expensive and better. The tires in the front are 235/60/15...JR, you’re right, I believe the backspacing is off (other owners fault) and that has something to do with the rubbing. So, I guess all there is to do is to buy stiffer shocks?? What kind? Here's the current pic with lowering springs installed
Old Nov 29, 2007 | 11:58 AM
1969 SS's Avatar
your tire height isn't really your problem then. the bottoming out is just something you are going to have to live with after such a radical drop, although your pics don't show that much of a drop at all. your car actually looks like it sits too high for even stock?
alsoyour shocks aren't going to stop you from bottoming out. that's what the spring does. your shock works the opposite way of the spring. one other thing is that if your car truly dropped 1 1/2", you should be looking onto a shock that is designed for that much of a drop. without the right shocks, they will bottom out on themselves and you will blowout the seals in no time
Old Dec 12, 2007 | 11:28 PM
camaro maniac's Avatar
1969SS is correct, the shocks only absorb the spring oscalations, they have nothing to do withyou bottoming out, you would have to switch the springs back to something with either a smaller amount of lowering, or you may be able to replace the springs with stock ones and put in some drop spindles, that may do the trick.
Old Dec 15, 2007 | 11:00 AM
1969 SS's Avatar
any updates on your progress?
Old Dec 16, 2007 | 01:34 PM
79T/Aman's Avatar
as others have mentioned shocks will not solve the problem but the back spacing is too little and the wheel is out too far
Old Jan 1, 2008 | 08:21 PM
RcrX's Avatar
for the frnt i'd go with 215/60
Old Jan 11, 2008 | 11:32 PM
1969 SS's Avatar
ORIGINAL: RcrX
those are way too tiny to get any decent performance out of them
Krusher RS
May 23, 2013 11:51 AM
the jank
Nov 5, 2010 04:06 PM
77nomad
Jul 25, 2010 11:46 AM
DarkKnight
LS Series Tech
17
Jun 18, 2010 10:05 AM
qmracer
Dec 11, 2007 03:03 PM
