just bought a 69 camaro (need help)
RE: just bought a 69 camaro
ORIGINAL: pugads650
i live in west covina california
your engine is going to need different mounts (no big deal), your tranny tunnel will need to be cut to fit the new tranny properly and you're out of luck with everything else. the suspensions in the two cars are 100% different from eachother
i will probably be getting rid of the motor and transmission, but in all honesty i wouldnt know how much to ask for them becaucse they both run great but arent very powerfull maybe around 180-200hp i dont think its putting out more than that.
but the car as is does a 0-60 in about 6-7 seconds but it feels like for ever for me being that my buick will do it in 3-3.5 seconds lol.
ohh one more thing
its also running a 1.75-2.0 exhaust i can wrapmy hand around it and my fingers touch it looks very restrctive
ohh one more thing
ohh by the way i picked up a low milage lt1 out of a b-body impala and brand new 4l60e transmission and all of the wirring. my question will i need to run a diffrent crossmemeber and will the transmission tunnel need to be modified thanks in advance.
jonathan
jonathan
#20
The tranny tunnel will definately have to be modified. The crossmember will need to be moved or a new one purchased. If you're looking to change the front and rear ends... whole lot a money! It's not just a simple bolt-up application. Why not do a mini-tub conversion. You can still keep the basic components and squeeze a little more rubber underneath without having to hack-out the entire rear section. The front end is another major job. Buy a new subframe or swap in another one like I'm doing ('71 Camaro) into a 1969.
I'd show you pictures but the video has everything on it.
Be really careful when taking the LT1 engine apart. That motor probably has cast iron heads and low compression pistons. You need the computer with it to get it all to work though.
You have a ton of work ahead of you. I know. I'm doing that right now. My engine's in the shop right now.
