Engine code confusion
Old Feb 12, 2019 | 03:48 PM
Buchananr's Avatar
Default Engine code confusion
111111
Old Feb 12, 2019 | 06:02 PM
peterpar's Avatar
Block casting numbers and it's date are only one part of identifying what car an engine came with. On the right front of the block is a pad with the partial serial number and codes that identify what that particular motor was installed in. This code would identify the motor assembly plant, date of assembly and the car it was to be installed in. A 1969 302 block code would end with DZ. The partial serial number should match the sequence portion of the car's VIN to be numbers matching. The attached pdf may help explain what I'm talking about.
Check the pdf that you've attached. You may not want that out on the web.
Old Feb 12, 2019 | 06:27 PM
Check the pdf that is attached. You may not want that out on the web.
Correct and delete that PDF
adam68
Apr 12, 2012 07:44 PM
michael A
Oct 14, 2007 12:33 AM
ecross4
Jan 6, 2007 09:24 PM
68RSCAMAROSS
Aug 24, 2006 10:18 AM
MHC68
Oct 2, 2005 02:15 PM
