Thread Lock on stripped spark plug threads
Old Feb 12, 2019 | 03:12 PM
Buchananr's Avatar
Default Thread Lock on stripped spark plug threads
69 Camaro with a 302 from a Z28. Can I use medium strength thread lock on stripped spark plug threads instead of tapping and inserting heli coils? The # 6&8 plugs are a "little" stripped. The plugs tighten fine but when I did a compression check the pressure gauge fitting would not tighten completely in those plug holes, but did in all others. The compression was consistent on those two cylinders at around 200 each?
Also, what compression range should I expect? Or is it more important to have consistency among the cylinders?
Old Feb 12, 2019 | 06:55 PM
MKCoconuts's Avatar
I would not use any loctite on spark plugs. I would personally pull and repair, but if the plugs thread in fine, you are probably good. Reason I say that is most compression testers have a very short thread length vs the spark plugs which go deeper and catch more thread. You want both high numbers and consistent numbers between cylinders. I'd have to go to a book to see what actual specs are, but I would say as long as you're within +/- 10 psi between all cylinders, you should be okay.
Old Feb 12, 2019 | 08:35 PM
Zspoiler's Avatar
No Loctite on your threads you will have issues otherwise, Just re-tap them if you have any issues
Old Feb 12, 2019 | 10:21 PM
Al Loyrat's Avatar
My 65/72 Chilton says 190 psi for 302.
Old Feb 13, 2019 | 07:06 AM
Buchananr's Avatar
Thanks very much for the responses.
redwhite79
70-81 V8 Tech
Oct 18, 2011 03:52 PM
ssoper89
Dec 16, 2009 04:28 PM
Orion
May 22, 2009 09:01 PM
shnormo
Oct 25, 2006 03:41 PM
davidalvarez82@hotma
LS Series Tech
Sep 7, 2006 08:16 PM
