Gapping Plugs
The spark will be hotter. This can cause "spark knock".
Larger gap requires more spark. More pressure in the cyclinders requires more spark. So you may see a spark failure (a miss) when under load.
Last, if it was way out your plug could hit your piston,
That depends on a great many things like, Piston shape, head design, even the type of plug. Many race type motors have very little clearance between the piston and the head and some of the high reving drag cars need .100 or more clearance because things tend to strech at the higher RPMs.
hoursetraitor
Apr 25, 2011 10:14 PM
