Carb help- stalling
Old Jul 7, 2017 | 09:02 AM
Robert Kendall's Avatar
Default Carb help- stalling
327 with 4mv quadrajet- after driving for a while at highway speeds, i put in the clutch to slow down, and while coasting to a stop, the engine stalls. When it does stall, it takes 10 -15 seconds of cranking before it will start again.
It feels like it is fuel starved, but pumping the pedal won't save it from stalling once it starts to sputter
My choke is currently disconnected (project for another day) but I have confirmed that it is open.
I rebuilt the carb a few weeks ago, and the problem has remained the same. I bumped the idle speed up a bit, hoping to lessen the problem, but it still stalls.
I just drove a parade, and had no issues at slow speeds. I think it is significant that it happens after a longer run at cruising speed (floats, maybe?)
Old Jul 7, 2017 | 02:19 PM
Everett#2390's Avatar
You add alittle more fuel to the bowl, and ensure the float is at the right height first.
The other action you could do is wrap the fuel line with insulation as fuel may be percolating.
Attach clothespins to fuel line and ensure the line on subframe is mot hitting or too close to exhaust header.
Old Jul 8, 2017 | 06:50 AM
I agree that vapor lock is a very good possibility but I have seen heat effect both coils and condensers in this way.
Old Jul 9, 2017 | 03:00 PM
Thanks, I will look into it. It seems that most of the times it happens is in the middle of a hot afternoon
Old Jul 9, 2017 | 03:01 PM
Good suggestions. Thanks for your reply!
Old Oct 3, 2017 | 07:39 AM
Still haven't fixed the issue, but I'm convinced it is vapor lock. I idled it for 10-15 minutes, revving the engine hard at times. it stalled without warning. When I opened the carb, it was bone dry. checked for line blockage, and there was none. Reassembled, started first try.
Currently deployed, so won't be doing this for a few months, but trying to research it from a distance.
Would an electric fuel pump solve this (in-tank or inline)? If so, any recommendations on brands/types/sizes, etc?
Old Oct 3, 2017 | 09:33 PM
Y2K's Avatar
Y2K
Is there an inline filter anywhere that might be clogged?
Are you sure the fuel pump is good?
Old rubber fuel lines can crack and suck air or collapse and block flow, how old are they do you know?
Electric pumps work great, I think I had a Carter on my '69 big block car feeding a Holley 750 double pumper, never an issue getting fuel, also had a pressure regulator inline.
Growler75
Nov 11, 2011 12:15 PM
albo1989
82-92 V8 Tech
Jul 1, 2010 07:40 PM
Riceeatingcamero
Mar 12, 2009 02:13 AM
JDman
Nov 13, 2006 01:49 AM
shaggie1
Apr 2, 2006 12:36 AM
