85 305 4bbl Stalling...PLEASE HELP ME
Old Mar 11, 2009 | 07:50 PM
Riceeatingcamero's Avatar
Default 85 305 4bbl Stalling...PLEASE HELP ME
I have a 85 camero with a 305 and a 4bbl quadajet. i am having a stalling issue, when i come to a dead stop i stall out not all the time. and when i am driving i am having a stumbling feeling, i have good fuel pressure, my idel in park is usaly 8500 but shes been around 6000.. when i am in gear its 6000, all my vacume lines are closes off. what do i do????? i went from a import to muscle and the carb is a new world for me..i reset the idel mixture, from 2 1/2 turns out. wat else could it be!!!!
Old Mar 11, 2009 | 08:45 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
So you Idle at 8500 and 6k?
Old Mar 11, 2009 | 11:01 PM
I'm sure you meant to drop a "0" in your idle description.
With a hot engine, remove the air cleaner, look down the throat of the carb, and see if the choke butterfly (front set) is wide open (straight up & down). Maybe your choke isn't opening?
Old Mar 12, 2009 | 02:13 AM
Choke is wide open, I pulld my tach wire thinking it could be a short, jumpd her she startd right up, I am gonna runn her hard tommorrow. And see wat I get, she only does it when I am drivn for a hour or so? Could it be my ecm? Or my coil, I have a excell distruibter wit a built in coil.UOTE=Camaro 69;298724]I'm sure you meant to drop a "0" in your idle description.
With a hot engine, remove the air cleaner, look down the throat of the carb, and see if the choke butterfly (front set) is wide open (straight up & down). Maybe your choke isn't opening?[/QUOTE]
Lindsay Boribon
67-69 V8 Tech
Jan 24, 2014 04:08 PM
Shadowscreed
82-92 V8 Tech
15
Apr 24, 2011 11:04 AM
Lurch019
70-81 V8 Tech
Feb 3, 2011 08:56 PM
Wyo77camaro
Nov 26, 2009 02:13 PM
CraZy Muffin
Apr 17, 2006 10:33 PM
