1968 Complete Frame Front/Rear
Old Sep 19, 2017 | 09:17 AM
1968Chris's Avatar
Default 1968 Complete Frame Front/Rear
New '68 restoration project start and looking for a budget friendly complete front/rear frame with disc brakes and quite honestly overwhelmed with the options available and the prices. I don't intend to race or go overboard with HP. Car is currently a basic (327 with 2 spd powerglide). My intent is to build with modern upgrades to add coil overs and a 4bar linkage in the rear with updates for disc brakes. I've seen a lot of very expensive "kits" that have beefed up frames and extensive upgrades I may not need. Any suggestions on mfg of complete kits that would meet those requirements without spending $10k?
New to this site as well, so any help would be appreciated!
Old Sep 27, 2017 | 10:33 AM
Ozzie68's Avatar
Outside of some of your needs /wants you can build a pretty fun car with some great bolt on from Hotchkiss, global West , or Cpp . CPP offers tons of upgrades your looking for at a reasonable price . I run Hotchkiss tvs with subframe connectors and CPP u/L CAs , I haven't driven the car a ton but it is a huge upgrade over stock suspension and give the car a great stance . I know your looking at a 4 link upgrade but look into some good leafs with good shocks and I think you'd be pleased
Old Sep 27, 2017 | 10:44 AM
CO68Camaro's Avatar
Hotchkiss and QA's I've always had good luck with, and as long as the subframe and rear frame rails are solid, that's the way to go without dropping $10g on a complete frame.
Old Oct 4, 2017 | 08:33 AM
1968Chris's Avatar
Thanks for the advice. I've since looked at some of the Hotchkis. Certainly seems reasonably priced. @Ozzie68, the stance on your camaro photo is what I'm looking for. Is that stock or a 2" drop? I really like that look and with larger tires and disc brakes I assume? Most of the "kits" I've seen for aftermarket frames are dropped, but I don't want the car to be on the ground.
Old Oct 4, 2017 | 10:57 AM
Ozzie68's Avatar
I run the hotchkis 1.5 inch rear drop spring with a 1” drop block and 2” front drop spring as the 3” stuff wasnt avalable back when i bought mine ‘ i also have 1/2 drop solid body bushing from glabal west running 17x 9 275/40/17 on back and 17x7 225/45/17 i plan on bumping front rim up to 17x8 with either a 235 or 245 . I have big disc brake dual piston up front and a s10 single piston disc in back. Car could come down safely another 1/2 or more all around but I dont have any interior pieces in and i figure the car will come down a bit after it is installed and more miles are on thr car.. ***side note*** i went with the koni adjustable on all 4 corners opposed to the tuned bilstein
jbrown68
Aug 11, 2017 04:26 PM
auto
Jul 24, 2012 02:05 PM
jcastner
Jun 20, 2012 11:47 AM
