switching from stock carb and ignition to hei and carb
Old Jun 23, 2010 | 08:27 AM
albo1989's Avatar
Default switching from stock carb and ignition to hei and carb
I am new to this site i was wondering what i have to do to switch to a carb + hei system can i use the same fuel pump etc i have a tbi and stock distributer now with the computer.
Old Jun 23, 2010 | 11:18 AM
The easiest way, without having to remove/bypass the in-tank pump, would be to install a return style fuel pressure regulator before the carb. Summit carries them. You have to drop the pressure, or gas will push right past the needle & seat and the carb will overflow. And, since the computer is what keeps the pump running now, you'll also need to re-wire the pump so that it runs automatically with the ignition key on.
Old Jun 23, 2010 | 04:41 PM
89 Red Devil's Avatar
Does anyone know if the roller camshafts have a fuel pump eccentric to run a mechanical fuel pump in this application?
Old Jul 1, 2010 | 07:40 PM
one92rs's Avatar
from my belief they are not on the cam after about 87 or 88.
Nate3408
82-92 V8 Tech
Mar 30, 2010 11:16 AM
greenklan
Dec 6, 2009 12:22 PM
bd92rs
May 15, 2009 04:01 PM
vampyrico
Apr 12, 2007 01:11 AM
JYori
Mar 29, 2007 07:10 PM
