Blower motor not wotking on Hi-speed
Old Mar 6, 2012 | 06:04 PM
adam68's Avatar
Default Blower motor not wotking on Hi-speed
I just installed a new blower motor on my '68 RS with Fact a/c. I tried it before putting the inner panel back on first.
The blower/fan blows on speeds low-med, but NOT on Hi-Speed. Any suggestions?
Thanks
Old Mar 6, 2012 | 06:09 PM
The blower switch probably went bad. If one of the lower setting were bad, the resistor pack would be suspect.
Old Mar 6, 2012 | 06:29 PM
When you "bench tested" the motor, was it hooked up to the dash switch and all 3 speeds worked?
Old Mar 6, 2012 | 08:24 PM
adam68's Avatar
I just put 12V to the motor to make sure it worked before install. As I said, lower 2 speeds work, just not Hi-speed.
On the old motor removed, it worked great on the 3 speeds, but made loud noises.
Old Mar 7, 2012 | 09:41 AM
adam68's Avatar
Default Blower motor issue
I found the issue. The ground wire on top of the A/C box was loose that comes of the sw. Now all is well.
What a rough job changing the heater core and blower motor. GM must have built the car around those items !!!!
Thanks for suggestions.
socalrs
Jul 17, 2011 05:00 PM
rwessels
Feb 22, 2011 01:18 AM
80rsguy
Mar 13, 2009 04:09 AM
The Banks
Oct 17, 2008 12:29 AM
jweb47
Jul 22, 2008 03:32 PM
