HVAC Blower Motor Help?
Old Nov 13, 2010 | 11:43 PM
rwessels's Avatar
Post HVAC Blower Motor Help?
The HVAC interior fan blows a fuse very quickly no matter what setting the fan is on. My thought is that I need to replace the HVAC Blower Motor, but how can I be sure?
Also, does anyone have pictures, video, or manual on where the blower motor is and how to remove it on my 1990 Camaro?
One last question, has anyone found an online or PDF manual for the 1990 Camaro RS 5.0
Thanks in advance,
Ron
Old Nov 14, 2010 | 08:20 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
I would try replacing the resistor before the whole motor.
Old Nov 14, 2010 | 12:57 PM
rwessels's Avatar
Thanks. Can you provide any insight as to where the resistor is? TIA, Ron
Old Nov 14, 2010 | 01:03 PM
rwessels's Avatar
Quick follow-up Q: would a bad resistor cause the fuse to blow...blown fuses are the primary issue and that's what made me think it is the blower motor.
Old Nov 15, 2010 | 05:37 PM
microkid's Avatar
March 2011 ROTM
Technical User
what amperage fuse are you using? have you tried a fuse with a higher amperage rating? will it blow at full speed? if so, that wouldnt be caused by the resistor. if it still blows, check the wiring on the passenger side firewall. if the fan motor is bad, it wont draw as many amps. its more than likely a short. does the fan work at all?
Old Nov 15, 2010 | 06:00 PM
rwessels's Avatar
Thanks for your reply! The stock fuse is 20 and we went up to 30 and it still blows.
The fan does work and sounds fine, but it used to blow the fuse after a few days. Now it blows the fuse after a few minutes.
Old Dec 31, 2010 | 01:30 PM
rwessels's Avatar
I took after the passenger side firewall cover, but I still cannot identify the fan. I am not seeing what I would expect.
Anybody have a 1990 view of the passenger side firewall area? BTW, I am now thinking it is definitely a short, but I still cannot figure out where to look.
TIA,
Ron
Old Jan 7, 2011 | 12:29 PM
carguy68ssrs's Avatar
The blower motor is just to the left of your ac box on pass side of car when you are standing in front of car. you can see the round end of the motor sticking out and the wire plugged into it. Blower relay is also right there, have someone turn blower motor switch from high to low and you can feel which one of the relays clicks so you know which one it is.
Old Jan 7, 2011 | 08:52 PM
rwessels's Avatar
Awesome, thanks. Please confirm that you are saying the blower motor and access are on the engine side of the firewall?
TIA,
Ron
Old Jan 7, 2011 | 11:49 PM
Yes they are
