69 Camaro pulls to left-why?
Old Dec 7, 2020 | 02:05 PM
lwh's Avatar
lwh
Default 69 Camaro pulls to left-why?
The car’s been pulling to the left for about 6 months. I had it aligned and it still pulls. Everything under the car is new and the alignment shop agreed that everything is tight. I found slight uneven brake wear so I replaced brakes, calipers, rotors, and bearings. It still pulls. I’m wondering if it’s possible for a power steering gear box to cause a pull. It’s a remanufactured box with about 3,000 miles. The alignment shop said their machine showed it responded immediately turning right but has a slight delay turning left.
Old Dec 8, 2020 | 08:41 PM
Get the front wheels off the ground, start the engine, keep hands off the steering wheel, and rev up the rpm's. See if the wheels want to pull more in one direction than the other. Could be an internal issue with the check valve, causing a hydraulic pull.
Old Dec 8, 2020 | 09:36 PM
Tires?
Old Dec 9, 2020 | 08:28 AM
lwh's Avatar
lwh
Thanks for the reply. I tried that. I even "encouraged" the steering wheel to turn on its own by giving a push.
Old Dec 9, 2020 | 08:32 AM
lwh's Avatar
lwh
Thanks for the reply. I cant move tires front to back since they are different sizes but I can swap side to side. The tires are designed to rotate one direction but temporarily swapping sides will at least tell me if the pull changes.
Old Dec 9, 2020 | 08:52 AM
Everett#2390's Avatar
Add more caster, min 1 degree.
Old Dec 13, 2020 | 05:54 AM
Avispa's Avatar
Swap tires front to back and recheck. Its unlikely to be a power steering box issue. Saginaw boxes use a torsion spool valve to run the hydraulics. They're self centering.
cwingert
Jun 21, 2018 05:58 AM
91camaro
Oct 13, 2010 10:31 AM
n269nando
May 9, 2010 03:27 PM
69camarokid
Oct 12, 2006 06:20 PM
sewerrat
Jul 12, 2006 04:11 AM
