Radiator - Stock or Aluminum, & where to buy from ?
Old Dec 12, 2020 | 01:06 PM
Spanky57's Avatar
Default Radiator - Stock or Aluminum, & where to buy from ?
I have a 69 ,396 ,4spd ,with a slightly radical cam , not sure what temp stat , but it runs around 180-190 , the radiator looks a little rusty on the lower 1/4 of the tank & fins , any suggestions what type of radiator to use ?
Old Dec 12, 2020 | 07:17 PM
Everett#2390's Avatar
Remove radiator and have a rad shop recore it.
Second choice, get another brass/copper radiator like OE.
Third, get an alum core rad with plastic tanks and pray a tank seam doesn't leak/break.
Old Dec 13, 2020 | 09:26 AM
Spanky57's Avatar
Thanks for for info , So , the 100% radiators are not the real deal ?
Old Dec 13, 2020 | 04:14 PM
SoCal67's Avatar
Look at Cold Case radiators.
A BB motor 1st gen, or small block with AC, came with the 23" core vs the smaller 21". They both fit
You can take your radiator to a shop if you can find one that actually boils and rebuilds old copper radiators.
Old Dec 13, 2020 | 06:56 PM
steve69ss396's Avatar
Cheapest and easiest path is to re-core the existing radiator. All aluminum radiators are not created equal.
roger1
Oct 24, 2010 02:31 PM
birkenmeyer68
67-69 V8 Tech
Sep 30, 2008 07:40 PM
jkkrs310
Jan 11, 2008 11:11 PM
Marroweter
Jun 11, 2007 11:32 AM
89RScammy
Apr 18, 2006 01:14 AM
