How to hook up electric choke carb
Old Nov 4, 2009 | 03:40 PM
Cblaze's Avatar
Default How to hook up electric choke carb
.how hard is it to hook up a electric one. i do not know to much about the electric part. the vehicle is gonna be converted from fuel injection to a carb if that helps ya any.
Old Nov 5, 2009 | 04:06 PM
Cblaze's Avatar
Disregard this thread please i figured out what i needed to know
Old Nov 7, 2009 | 09:37 PM
mighty mike's Avatar
accually explain cuz im thinkin bout it to but not sure
Old Nov 7, 2009 | 10:19 PM
Cblaze's Avatar
From what edelbrocks site says all you gotta do is hook up a ground and a twelve volt wire that turns on with when you turn your key
Old Nov 9, 2009 | 09:39 PM
cant be that easy. plus then that means itll always be on right?
Old Nov 10, 2009 | 09:41 PM
Cblaze's Avatar
It actually is that easy.i just called the summit racing technical support people to confirm it.
Old Nov 10, 2009 | 09:47 PM
Cblaze's Avatar
Also gonna add he said it knows when the choke needs to be on and when it doesnt.
Old Jan 30, 2011 | 10:34 PM
privatehoskins@aol.com's Avatar
Default fuel injection to carburated
it's difficult going from fuel injected to carburated.. i had the 350 tpi and switched to carburated. the worst thing was gettin the fuel pressure rite at first i thought i would leave the electric fuel pump hooked up and it would work.. well 30 pounds of pressure is a little much on a carburater so we regulated it. i dont know if this is what happend but the fuel pressure all the sudden would go out i though mayb the ecm was shutting down the fuel pump. so i gave up on that idea and i got a stock manual fuel pump for a 86 silverado and put it on. after that my maunal pump wasnt getting enough pressure because it was sucking through the stock fuel pump so i cut a hole in the trunk and replaced the stock fuel pump with a piece of hose and i strapped it on with several zip ties. i didnt make it to long i didnt want it suckin up anything from the bottom of the tank. that fixed my fuel problem.. the next hardest thing was to find parts for the top end that fit under the hood.. all i could fit was an 8 inch air clener. everything else hit the distributor and i couldnt put a riser because it hit the hood..
Old Jan 31, 2011 | 07:09 PM
roadkillracing's Avatar
if memory serves me correctly you use the stator terminal on the alternator as it is only on whe the car is running.
jeffchairs
Sep 7, 2014 02:25 PM
80ZJoe
70-81 V8 Tech
Jun 13, 2011 09:56 PM
sewerrat
Jul 6, 2008 04:15 AM
thenn3025
Jul 12, 2007 01:49 PM
