305 to 350 need a new computer?
Old Jan 31, 2011 | 12:42 PM
TyroneLang's Avatar
Default 305 to 350 need a new computer?
Hello, I'm putting a 350 into my 86 Camaro which has a 305 at the moment, and I'm wondering if I need a new computer or if I can just add a new chip into the old one. Thanks
Old Jan 31, 2011 | 12:58 PM
carguy68ssrs's Avatar
Just do the swap, I didn't change anything on mine
Old Jan 31, 2011 | 07:16 PM
microkid's Avatar
March 2011 ROTM
Technical User
are you running tbi or tpi? im not sure about the tbi, but there are significant differences between the 305 and 350 that can cause issues and poor performance. the 350 has a different fuel map, and requires 22 lb/hr injectors. the 305 uses 19 lb/hr. the knock sensor is also different. at the bare minimum, get the chip, injectors, and knock sensor for the 350. if you have any performance mods done like headers, lower temp thermostat, etc. visit www.pcmforless.com and get a custom tune. its a bit more expensive than finding a used chip, but will get you more power. as for tbi, im not sure if the physical unit is any different, but the injectors are. you can source them new or used
TyroneLang
82-92 V8 Tech
Apr 6, 2011 07:49 PM
Christophern
Nov 29, 2010 11:04 PM
94Z28interceptor
Jan 28, 2007 01:30 AM
motor tec
Nov 14, 2006 10:41 PM
