Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
Hood Issues
Old Jun 8, 2006 | 02:19 PM
Torque Junky's Avatar
Default Hood Issues
I posted this in general tech and got no response, so I thought I would try here:
My Second Gen has a fiberglass cowl hood and I'm having trouble getting it lined up. I have got it adjusted where the hood sits flush next to the hinges and up front by the latch and it isn't even close to touching the adjustment screws. In other words, it is sitting up too high on both front corners, is there any way to fix this without doing mud work or pinning the hood? Swaping out the hinge springs for lower tension springs wouldn't do anything to help right? I am not too familiar with working on fiberglass, I am unsure if I can reshape it without damaging the paint, so I'd appreciate any help...
Old Jun 12, 2006 | 04:09 PM
mattvogt's Avatar
Default RE: Hood Issues
I put my fiberglass L88 hood on my car yesterday and I had the same problem, I dont have hindges yet so its just sitting way to high in the back, first i took out the ajustment screws and that helped some but now I have problems with the windshield wipers fitting. I have a 81 by the way, Dont know whats up with it. Let me know of any solutions.
Thanks.
Old Jun 12, 2006 | 11:58 PM
bowtieguy's Avatar
July 2009 ROTM
i have a new s/s metal hood for my 78 and i had wiper issues .you have to use the factory arms and blades.aftermarket arms and blades were about 1 1/2" taller than factory.i still have to figure out something else for the window washer squirters.
Old Jun 14, 2006 | 11:57 AM
mattvogt's Avatar
Where do you buy the aftermarket wiper blades, I cut the bottom out of my hood so that it will fit better, It was used so if it dosnt work im only out 50 bucks.
Thanks for the help.
Old Jun 14, 2006 | 01:55 PM
bowtieguy's Avatar
July 2009 ROTM
when i say aftermarket i'm talking about the arms and blades you buy at auto zone,ect. those arms and blades were alot taller than the factory stuff.my driver side was alright ,the passenger side would have hit the hood,thats why i went back to the factory stuff
Old Jun 15, 2006 | 05:23 PM
mattvogt's Avatar
Ok, thats what I thought, Not sure if it was generic or if it was intended for the camaro. Thanks. Matt
midwestdave33
May 25, 2012 05:32 PM
timmyz28
Apr 6, 2011 01:47 AM
endo
Aug 9, 2009 09:31 PM
Failed Devices
Jun 30, 2009 05:21 PM
ScottD
Oct 27, 2006 06:37 PM
