V6 TURBO Questions
Old Mar 5, 2007 | 02:05 AM
bumpnbrd2005's Avatar
Default V6 TURBO Questions
Anybody an expert on how much PSI a 2000 V6 3.8L can handle without having to modify the intake and injectors? I was guessing you'd be safe with 4 to 5 PSI, and anything more than that you'd have to do a little more engine work. Thanks in advance, I appreciate it.
I was hoping for 3-5 PSI. If I replaced the injectors, and then got a Reprogrammed PCM, do you think I could run 5 PSI? What else would I need to replace to achieve 5 PSI. Ultimatly, that is my goal. There are a couple other questions I have.
1) All of the rear mounted turbos I've seen, use metal piping all the way back up to the intake. I know STS does that, to eliminate the need for an intercooler, but can you use rubber hose (Like radiator) that has a proper thickness and diameter? and then run it through an intercooler in the front to eliminate the majority of the pipe fabrication? I just thought I'd throw that out there, I mean, the intake air isn't very hot, and the only reason I could see for running pipes that far would be to cool it, and maybe durability.
2) The second question I have regarding this topic, is they recommend Dyno tuning, what exactly is that. Can a normal dealership do that? Or do I need to take it to a specialty company? If I got the PCM reprogrammed for the turbo, would that be considered Dyno Tuning, since it's a PCM reprogram that takes into account other things like injectors, and turbo.
Thanks Again.
Old May 26, 2007 | 10:29 PM
badinfluenceRS's Avatar
Default RE: V6 TURBO Questions
check out camarov6.com or fullthrottlev6.com
beta383
Jan 22, 2015 08:56 PM
Adamloveshis99camaro
Jan 14, 2009 04:21 PM
grgl89
Sep 14, 2007 02:52 PM
red star
Aug 22, 2007 06:53 PM
red star
21
Aug 15, 2007 10:25 PM
