Old Sep 17, 2011 | 01:16 AM
  #111
Holy crap what a deal. Do they have baffles?
Old Sep 17, 2011 | 09:05 AM
  #112
Yes, they are baffled, and the sale just started this week.
KMJ Performance :: Valve Covers :: POLISHED SBC CHEVY FABRICATED ALUMINUM VALVE COVERS
Old Sep 17, 2011 | 09:30 AM
  #113
kyphur's Avatar
Those fab'd valve covers look really nice. I almost went that route but ended up going with cast aluminum from Edelbrock. Still, those rock on that setup. Nice choice Mr. Val.
Old Sep 17, 2011 | 09:54 AM
  #114
Thanks! I've always liked them, but many vehicles don't have room to use them. Wanted to put them on my Camaro, but way too tight to even consider them without deleting the heater and getting a smaller brake booster.
Old Sep 17, 2011 | 09:58 AM
  #115
kyphur's Avatar
I have the high profile Edelbrocks on mine and I don't have too much of a problem. The worst is the regulator bracket that I have on the passenger side. I have to take the bolts out of it that hold it on the carb base but that's it.
Oh wait, forgot that you had that monster of a big block under the hood.
Old Sep 17, 2011 | 10:01 AM
  #116
How would you rate the quality of those covers; fit, finish, sealing, thickness? And are they natural or clear coated? I thought about getting fabbed covers to get "that" look, but not for the high prices most are going for. 60 bux is stupid cheap, as long as the covers aren't cheaply made.
Old Sep 17, 2011 | 10:03 AM
  #117
kyphur's Avatar
I've seen some really good ones for around 100 bucks not including shipping out of a place here in Alabama. If I can find their site again I'll post it if you're interested.
Old Sep 17, 2011 | 12:49 PM
  #118
I agree I have seen decent ones for around $100. I was also wondering about the thickness. Do they oil can? I'm not worried about the finish as long as there not coated. It is a ***** to get that off to polish them. I wish I had 60 to blow. I had to get a wheel bearing for the womans car this week though.
Old Sep 17, 2011 | 06:08 PM
  #119
The sealing lip is 1/4" or slightly thicker, so they seal very nicely. The allen head bolts that come with them can really be cinched down easily, and the design keeps them from warping if pvertightened. The welds look really good, maybe done by a machine. They are polished, but not clear coated, so they will need to be occasionally polished as they dull.
I saw a lot for slightly more, pllus shipping, but none of them had breather holes and baffles. Only thing I can say negative, is the same for every fabbed valve cover 've looked at; they don't have a lip for the gasket to sit into. I used black RTV and 1/4" bolts to align them and let it sit for a couple hours before installing them, and they sealed great. After driving to and from the cruise today I had none of the oil film on the outside the valve covers that I previously dealt with on the non baffled Corvette valve covers. At $60 shipped these are the deal of the century, I'm really happy with them.
Judges liked them today too, the Austin won "Favorite Hot Rod" today!
Old Sep 17, 2011 | 09:20 PM
  #120
I use studs on mine. Mostly because of the aluminum heads. I would hate myself if I were to srip out the bolt hole. I don't think there is enough meat for a heli coil.
Anyhow, the gaskets just slip on the studs and away I go. I don't even use gasket sealer. You'll find that with your AFR's the gasket surface is milled flat. Combine that with your covers with machined surfaces, it shouldn't leak ever.
