Should I use the nitrous...
RE: Should I use the nitrous...
mine is tuned and I run a wet kit which is more forgiving on the tuning because the fuel is added. u were running a 125 dry kit without tuning. thats crazytalk.
and the pic is a genI 350, not an lt1 which is genII
The highest i have ever seen is a 200 wet shot on a freak bottom end. The guy is running a small 1 gallon reserve with higher octane fuel for the sprayer and is very well tuned. But as i said this is a factory freak LS1 and its only a matter of time in my book [>:]
its also not going to benefit me untill i get a new bigger cam...oh BTW i called the dyno it appers the dyno was set up wrong for my car so you where right the dyno screwed me over..now i got a fake 400+hp car.
do you know what kind of dyno they used? you should scan your graphs in and post them, you can learn alot from all the numbers, not just peak hp numbers. what was your torque?
EDIT: but dont answer here, lets not hijack threads and spread your cars discussion over several pages. "pack of ricers" is probably a better place if were going to talk about ur graphs
likearock91288
08-13-2007 09:18 PM
