Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Carb turbo concerns
Old Oct 25, 2009 | 10:05 PM
Starquest's Avatar
Default Carb turbo concerns
Hey there guys. I actually have joined the forums here to seek advise seeing as I can't find any from other sources. I have an '89 Starion GSR-VR and intend to run a carburated turbo setup, but having almost no background in carburation, I'm at a loss. I was pondering on a couple of things: What kind of injectors would I be looking into (variable-flow or who?), how would I go around tuning the system to not run rich when in vaccuum (or extremely lean when in boost) and the effects of running open-dump or recirculative-dump BOVs. Any help would be greatly appreciated and if you guys have any other ideas I should look into, I'd appreciate it alot if you were to express them to me. Thank you much for your consideration and I hope to hear from you guys.
Old Dec 5, 2009 | 10:03 PM
oxigide09's Avatar
Basically Almost everything you do To the engine is HP, Turbo, Intake, BOV.. Ect, ect
Old Dec 19, 2009 | 12:27 AM
Sharronholloran's Avatar
Recently i blew up my 350 and am currently building it into a 383. i am certain i want to try a turbo set up on it and have seen a few members here with turbo setups and know there are other knowledgeable folks here. so i am looking for advice. i would like to go with a single turbo set up so it isn't too radical and for simplicity.
SSTHUNDER
2010+ Transmission
Mar 5, 2012 09:16 PM
SSTHUNDER
Feb 10, 2012 11:35 AM
Faalvino
82-92 V8 Tech
Dec 25, 2011 01:09 PM
Senshi09
Nov 7, 2011 08:34 PM
