1997 camaro v6 fuel problem help please
Old Oct 11, 2012 | 09:16 PM
thatkidsanti's Avatar
Default 1997 camaro v6 fuel problem help please
Can someone help me i have 97 v6 camaro . Im having a problem with it.
It starts and just shuts off not even trying to idle . I have changed the fuel pump, the air idle control valve , the MAF sensor, the Map sensor, the fuel pump relay, spark plugs , coils. And nothing . I tried starter fluid and kept spraying it until the can ran out , the car will stay on until the can had nothing feel then the car with shut off yet again . I checked to see if the fuel rail had any fuel pressure and it doesnt. Can it be the fuel regulator causing the problem ? HELP
Old Oct 12, 2012 | 04:30 AM
sprocketser's Avatar
Welcome aboard . I guess you should get an estimate from a Chevy dealership before putting in loads of money in the car without have the solution , I know i did it years ago ...!lol
Maybe one will chim in & know what s up with it too .
Old Oct 12, 2012 | 03:06 PM
JoshMan's Avatar
Does the car stay running if you hold the gas down slightly to make an artificial idle?
Old Oct 12, 2012 | 08:28 PM
The engine has to start within about 5 seconds or the PCM will remove power from the pump. You should be able to feed power directly to the pump using the priming test connector in the engine compartment. Also check the fuel injection fuses that provide power to the injectors.
Old Oct 16, 2012 | 07:12 AM
Thank you everyone. My car is running fine now. I found out my fuel pump relay was going bad. And it seem i need to turn the key on and off like 2 or 3 times and crank it and it starts up normally . Seems that i should get a new sending unit .
Old Oct 16, 2012 | 03:22 PM
sreed1236's Avatar
have u checked the fuel filter? or put a fuel pressure tester on it? u may have a clogged fuel filter
Hazard29
Dec 11, 2014 08:04 PM
weasel348
Jun 18, 2012 10:07 PM
Hazard29
Apr 28, 2011 02:47 PM
mykegriffin
Mar 10, 2008 11:36 AM
ideal567
Dec 23, 2005 05:34 PM
