LT1/LT4 Tech 1993-1997
Won't start intake backfires
Old Jan 15, 2007 | 09:05 PM
95redcam's Avatar
Default Won't start intake backfires
I have a 95 z28 with 40,000 miles on it.
I just purchased a new accel distributor, plugs, wires and new headers.
After instalation the car ran for about an hour and just died at the stop light.
I called a mechanic over and we tried putting in a new coil and ignition modual, but still no luck. He assured me it was the distributor even though it was new cause I wasn't getting a spark. I just installed another new distributor and now the intake backfires exhaust smoke after cranking.Itwasn't doing this before. I'm almost postive the distributor is on right, I positioned it until it fell into the pin hole but still wasn't completely flush (about a couple centimeters off the cover). All wires are in correct order.Fuel preasuer is 39psi at regulator. Please help!!!
Old Jan 15, 2007 | 09:15 PM
ghotachevy's Avatar
Default RE: Won't start intake backfires
timing is still off 180 out maybe
Old Jan 15, 2007 | 09:22 PM
95redcam's Avatar
sorry stupid question but what does that mean
Old Jan 16, 2007 | 07:08 PM
95redcam's Avatar
I thought that the vented opti spark can only go on one way.
Old Jan 16, 2007 | 11:32 PM
They can only go in properly ifthey arealigned properly with the drive pin. However,theycan go in any old way if one does not align it with the drive pin, and then it won't run right, or may even damage the distributor. Pull the distributor out and put it back the right way. Get a service manual with pictures.
xCrazyHorse
Dec 19, 2020 11:05 PM
HappySalesman
LS Series Tech
Jul 18, 2014 12:10 AM
kdhale21
Nov 20, 2011 10:34 PM
White94Z28
May 22, 2010 12:27 AM
mebmatt
Apr 3, 2007 12:01 AM
