LT1/LT4 Tech 1993-1997
clutch
Old Dec 23, 2006 | 05:09 PM
yamahar6one's Avatar
Default clutch
Last night was bad,on my way to get dinner and went put it in six gear and my clutch pedal just went to the floor.There was no warning at all.Its a 93 z28 with 122,*** miles on it.Msd 6al,cat back,K&N,52mm body.Ive check master cylinder and its got fulid,no lines are hanging off.Anybody have any ideas before I buy a new clutch.Right before christmas too.Marry christmas guys
Thanks Chris
Old Dec 24, 2006 | 12:02 PM
shnormo's Avatar
Default RE: clutch
Well it's not your clutch. It's the hydrolic system. I would check the cylinder for leaks, and the lines. If there is nothing leaking from there, you might have a bad throw out bearing. I would fill the cylinder up and see if it holds fluid still. If brake fluid came in contact with the clutch friction material, it should be replaced.
Old Dec 24, 2006 | 02:39 PM
Default RE: clutch
Thanks thats what I was thinking.Wanted to see if anybody has had this,its not leaking any fuild.So looks like the tranny is coming out.Whats a good clutch to put in?I may put some no2 on it down the road.
Old Dec 24, 2006 | 04:15 PM
Default RE: clutch
The hydraulic cyliders can go bad without leaking externally.
Old Dec 24, 2006 | 08:58 PM
shnormo's Avatar
Default RE: clutch
A zoom clutch would be fine for a moderate shot of NOS.
Old Jan 18, 2007 | 01:28 PM
NICDZ28's Avatar
Default RE: clutch
I HAD THE SAME PROBLEM WITH NO CLUTCH PEDAL AND MINE WAS A BAD SLAVE CYLINDER
Old Jan 18, 2007 | 01:29 PM
NICDZ28's Avatar
Default RE: clutch
I PUT A RAM PRO GRIPPER 3 CLUTCH IN MY CAR AND IT PERFORMS GREAT 8 SPRINGS AND NO SLIP ALSO NOT AWFULLY EXPENSIVE.
dogdog130
Jun 28, 2012 04:28 PM
locotrician
May 16, 2009 11:18 PM
bluegreenta
Dec 21, 2008 09:24 PM
Rise65
Nov 8, 2007 10:58 PM
Pro_built7
Apr 10, 2007 02:07 AM
