LT1/LT4 Tech 1993-1997
Weird Problem Starting
Old Feb 9, 2009 | 07:41 PM
ryan88z's Avatar
Default Weird Problem Starting
Every once in a while my 95z lt1 wont start. I have a fully charged battery and starter is about 6 months old. What happens is when i try to start the car all i hear is a click and thats it. If I disconnect the battery for about 1/2 hour and put it back on the car will start up no problem. Any Ideas.
Thanks
Ryan
Old Feb 9, 2009 | 07:52 PM
Saint_Ali's Avatar
i would suggest replacing the ignition switch
Old Feb 14, 2009 | 11:08 PM
stonecoldtrk's Avatar
to me it sounds like your battery terminals are bad or possibly loose or corroded. thats usually what happens when you just get a click and everything dies but you know the battery has power. i bet when you turn the key back off and then to the on position again all the lights come back on but trying to start gives you a click and everything is dead again, i would clean or replace the cable ends and see if that helps,
Old Feb 15, 2009 | 07:34 AM
ryan88z's Avatar
I've got a new battery and new terminal ends . battery is clean.
Old Feb 17, 2009 | 01:01 PM
pockets47's Avatar
Try hitting the solenoid with a screwdriver and change the battery terminals. I've have had the same problem with my 5.0.
Old Feb 17, 2009 | 08:14 PM
rondavis's Avatar
does your security light come on when it is not starting if it is just wait for it to go off and try agian mine does this every once in a while after that i would try and get a key from the dealer
Old Mar 9, 2009 | 02:36 PM
SeaBass1020's Avatar
My 95Z does the same thing. Sometimes I turn off the ignition, then try again and it starts by itself and sometimes I need to get under it and play with the connections on the back of the starter motor. Feels like something is loose there, but I can't figure out exactly what. Anyone?
Old Mar 9, 2009 | 06:08 PM
ryan88z's Avatar
yeah it drives me nuts no ses or security light on . gotta push start it sometimes and i hate doing it
Old Mar 9, 2009 | 09:01 PM
just a suggestion. to tighten the wires you will most likely haver to take the starter lose so you can have access to them. either the wires or the start itself could be lose. in some of the old cars iv had the starter bolts were lose and did not get a good ground sometimes.
warehimer33
Dec 1, 2010 04:30 PM
wolfy692005
May 19, 2010 11:23 AM
traumadog
Mar 30, 2009 10:38 AM
hevymetalg
Oct 11, 2008 06:42 PM
jdubs1813
Mar 18, 2007 03:04 PM
