LT1/LT4 Tech 1993-1997
Water Pump
Old May 18, 2010 | 11:47 PM
Z28camaro94's Avatar
Default Water Pump
Hey. I have a 94 Z28 camaro and my water pump is bad I am in the process of replacing it but ran into some problems with getting the water pump out. Can anyone help me and let me know what I need to do to get it out.
Old May 19, 2010 | 12:31 AM
Are you having problems gaining access to the pump, or getting it off the block in general? Make sure you get all the mounting bolts off, there are three on each side holding it on. The lower bolt on each side is tucked in there and can be easy to miss.
Old May 19, 2010 | 08:23 PM
Grandpaswagon's Avatar
If you have the bolts out, and the pump is free but you just can't find the room to get it up and out, you can remove the fans. It will give you another 1 1/2" or so to move it around.
Old May 19, 2010 | 09:46 PM
rwing7486's Avatar
You just need to remove your passenger side fan for enough clearance...and like 69maro said...make sure you get all three...very easy to miss the one on the left hand side tucked in the back
Old May 20, 2010 | 08:28 AM
Default water pump
Thank you. Now I have it out another problem how do I get the coupling off the old water pump drive shaft to put on the new pump drive shaft?
Old May 20, 2010 | 10:08 AM
u can put some vice grips on it and use them to pry on with a couple screw drivers. dont forget to change the water pump shsft seal on the timing cover. 69 has a nice writup on doin it in a sticky.
Old May 20, 2010 | 04:53 PM
Mine was corroded in place. I tried the vise grip trick without luck. I tried soaking in penetrating fluid without luck. I finally heated it up with a propane torch and it came off like buddah. I wasn't worried out damaging the pump as it was a core return.
Old May 22, 2010 | 03:47 AM
bisgardb's Avatar
A little late but if you still have the waterpump off its a good idea to change the opti distributor as the water pump needs to be removed to do this
VALHAR
Dec 4, 2010 11:51 PM
cadmanof50s
Sep 22, 2010 08:38 PM
imcdowel
May 8, 2010 10:13 PM
camarorz28
Jan 27, 2008 02:57 AM
