LT1/LT4 Tech 1993-1997
water pump
Old Jan 18, 2008 | 06:40 PM
camarorz28's Avatar
Default water pump
i just notice that i have coolant sligtly dripping into my crank shaft pulley, i really dont have alot of money on me right now. What are the chances my opti spark going bad what do ya say?? and does things are expensive lol??? Also is there any pictures that would show me how to replace it, i know there is a shaft coming out to the pump is there any way that it needs to go other than the wrong way
Old Jan 18, 2008 | 07:38 PM
95slvrZ28's Avatar
Default RE: water pump
If there's fluid dripping onto your opti there's a very good chance that it'll die, because that's what does most of them in. A new opti from GM is around $300 I believe.
Old Jan 18, 2008 | 08:04 PM
This site has some good info on replacing the opti and the water pump. Especially on how the shafts should look and how they need go in, in order to avoid leaks in the future.
http://www.automotiverebuilder.com/ar/ar99928.htm
Old Jan 18, 2008 | 09:30 PM
camarorz28's Avatar
so if the shaft is grooved it has to be replace right?? to what the article says, in the Haynes Repair Manual it says to remove the coupler from the drive gear and check the seal surface on the geared shaftfor grooved shaft. Also should i replace the O-ring seal??
Old Jan 19, 2008 | 11:05 AM
If the shaft is grooved then the seal is probably worn out also.
Old Jan 27, 2008 | 02:57 AM
ss.slp.ls1's Avatar
Are you sure its your water pump leaking? Borrow a pressure tester and check for leaks, it may just be a rubber hose. You'll know when your opti is going bad, your car will run like s***. I had to replace mine the other night. The water pump comes off and goes on only one way. Theo rings on the shaft should be inside the timing cover, the only thing you should need would be new gaskets.
VALHAR
Dec 4, 2010 11:51 PM
cadmanof50s
Sep 22, 2010 08:38 PM
imcdowel
May 8, 2010 10:13 PM
robmnrd
Feb 10, 2009 02:58 PM
