LT1/LT4 Tech 1993-1997
Trouble starting after winter season
Old May 22, 2010 | 09:02 PM
Mattroy8812's Avatar
Default Trouble starting after winter season
My 1997 6 speed LT1 is barely cranking over when I try to jump it. It is arching at the positive terminal. Battery and alternator connections are tight. Started it a month ago and it was fine but now cannot start it. Headlights are at full power but cuts out when I try to start and when i pull the jumpers off it goes dead instantly. Summers coming
Old May 22, 2010 | 09:21 PM
osduck5's Avatar
Take a wire brush to the battery terminals as well as the wiring connections on the fender well. Clean them really good. Might also want to check the other ends where the positive connects to starter and the neg connects to ground. Make sure you get them shiney clean. Battery may be so dead that it cannot even be used to jump start.
Old May 22, 2010 | 11:14 PM
^^^ agree either bad connection or bad battery.
Brandon1992
Jan 13, 2011 10:09 PM
Bubonic
Dec 2, 2007 06:01 PM
dasota
Jul 7, 2007 04:19 AM
ilovemycamaro
Nov 5, 2006 11:30 PM
