LT1/LT4 Tech 1993-1997
tune for heads cam and s/c
Old Sep 21, 2006 | 04:45 PM
redchevy89's Avatar
Default tune for heads cam and s/c
i have trickflow heads for a s/c comp cam for s/c and a procharger system with 10psi i know i should have learned how to properly tune it before i did it but i need a tune, the car runs but im not sure if its running to lean.
Old Sep 22, 2006 | 07:07 PM
Default RE: tune for heads cam and s/c
Contact www.pcmforless.com. They will tune the computer to your specs on an exchange basis. Otherwise get a tuning program that you can run on your laptop and change your PCM parameters.
Have you installed larger injectors??
Old Sep 23, 2006 | 04:15 PM
redchevy89's Avatar
ordered bbk 52mm should i have gone to the 58?
Old Sep 23, 2006 | 04:35 PM
I am talking about injectors, not throttle bodies. The 52mm throttle body shoud be OK, but I don't think the stock injectors can deliver enough fuel.
Old Sep 23, 2006 | 05:26 PM
redchevy89's Avatar
what would you recommend?
Old Sep 23, 2006 | 06:54 PM
I would think, 36lb injectors should be enough. However, before you invest, check with the persons who are going to do the tuning & see what size they recommend.
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
1983_JAL
Mar 23, 2007 11:57 PM
